Old 01-14-2007   #1
jrd1990zr1
jrd1990zr1's Avatar
Default 1990 Power switch
Does anyone know how to test a power switch out of the car? There are three pins, I have a complete circuit thru the common pin and one leg with the key on. The other side appears to be open.
Thanks for the advice
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 01-15-2007   #2
368zr1
368zr1's Avatar
Default Re: 1990 Power switch
As you can see on the schematic only 2 pins on the Valet/Power Key Switch are used.
When the switch is in Full Power Mode, the Dark Blue/White wire
is connected thru the switch to ground.
368zr1 is offline   Reply With Quote
Old 01-16-2007   #3
90ZR1
I just had mine re-wired to always have the power on... is what the ZR1 craves!
90ZR1 is offline   Reply With Quote
Old 01-16-2007   #4
jrd1990zr1
jrd1990zr1's Avatar
Thank you
