07-26-2016 | #1 |
Dr. Jackyll and Mr. Hyde
07-26-2016 | #2 |
Re: Dr. Jackyll and Mr. Hyde
you are going to want to Hyde when the repair bills on the SL start coming in
For My SL600 since I bought it 10 weeks ago; of which its run about 2 *$155 hyd suspension hose failure(I replaced myself) *Trunk release($500 part) I fixed part and replaced *Radiator failure($250) I replaced myself *Cracked Rim $200 *New rear tires $600 *$1400 coil failureD/S(replacing now) *$1400 coil failure P/s(Replacing now) *24 spark plugs @ $8 Per(I am replacing, Mercedes charges $1200)
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 07-26-2016 at 10:45 PM. |
07-26-2016 | #3 |
Before I pulled the trigger, I asked Dempsey if he could work on Mercedes and his answer was "f**k yeah!". So I pulled the trigger.
07-26-2016 | #4 |
Its not the work, its 1)Part Cost 2)They make it a pain in the *** to pull trouble codes.
07-26-2016 | #5 |
Yun, Good call you can never go wrong with a V12.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
07-26-2016 | #6 |
Its a V8....Yun is that the NA or TT motor?
07-27-2016 | #7 |
07-27-2016 | #8 |
NA. 5.5 liter quad cam, 382 hp/391 ft lbs. Sounds familiar? It has variable valve timing and variable intake (dual length).
You do need a good scanner to pull codes and reset reminder/trouble lights. So, I have a icarsoft MBII i980 scanner coming. Last edited by secondchance; 07-27-2016 at 05:54 AM. |
