05-27-2016 | #1 |
90 ZR1 black/black hi mi motivated seller
My old Z, has higher mi.
Cannot remember if it was 160 or 180k Posting it for owner, hes not a web person Bob 818 209-5113 Not thrilled about selling it one of those things. If it happened fast would help, if he could wait then keeping its a good thing something like that. Relocating biz to Nevada reason cant leave car here The good Ujoints done Silver 95 Amolds ZFDoc went through the trans, slave believe clutch too Aftermarket brakes/rotors Aftermarket stereo/amp Nittos Moracca valved Bilsteins Haibeck chip 4.09 gear Corsa catback SRP stat Black samcos 40k on water pump DeWitts radiator with spals Hurst shifter Guldstrand supposedly rebuilt the cats Probably more I cant remember The bad cosmetics basically Paint is faded Interior showing some wear &tear Has draw on battery. Suspect fuel pump connection (happened after an "expert" installed a NOS ZR1 pump. Something simple sure a few hrs with a multimeter could solve. Would start then peter out I cant work on it anymore nobody out here really does so it was to sit til he could get it out ZFDocs way again. Been sitting for approx 6mos? +- Has a TON of extra parts, all new suspension pieces, ECM too much to list Bill "ZFDoc" has done lots of work to it knows it well Mechanically pretty strong/sound, needs a little time with a multimeter and someone whos not needing perfect paint, int. Looking for 10...cash talks I suppose you guys know the drill. Good part is rearend trans shocks tires cooling fuel are strong not much to worry about there. Could make a good driver or track car without worry of getting keyed We all know the market is bad on cars period is what it is.
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. Last edited by cuisinartvette; 05-28-2016 at 07:29 PM. |
