05-03-2016 | #1 |
Z06 Wheels - About to pull trigger, need a little advice.
I'my about to buy some Speedline Z06 wheels with 345/19's and 275/18's. GOOD tread and I need another set of rear tires, I think for 800$ these will fit the bill...
I've seen 20mm adapters on EBay with spline style lug nuts for 60$ Is that the correct width spacer? Any links to the 'perfect' spacer?
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
05-03-2016 | #2 | |
Re: Z06 Wheels - About to pull trigger, need a little advice.
05-03-2016 | #3 |
Check out this post from Jagdpanzer. That top bolt interferes w side wall.
I found that the DRM BRACKETS really help with control wheel travel and so the rear inner fender wells did not need trimming. There are other subtle differences between my install and Phil's. http://zr1.net/forum/showpost.php?p=234707&postcount=13
05-03-2016 | #4 |
