04-10-2016 | #1 |
Replacing clutch safety switch
Anybody here actually replaced the clutch safety switch instead of bypassing it?
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
04-10-2016 | #2 |
Re: Replacing clutch safety switch
Why would you want to do that?
04-10-2016 | #3 |
Jumpering out the switch is MUCH easier!
04-10-2016 | #4 |
Because I want to and I need it for NCRS. It's a safety feature. I did that to my 92 ZR-1 and I've tried to start the engine several times with it in gear and because I hop back and forth between automatic Vettes and manuals.
04-10-2016 | #5 | |
PITA.
04-11-2016 | #6 |
04-12-2016 | #7 |
Doug, you keep bringing that up. There are no checklists on cars! I've decided to jumper the contacts and when the time comes, just pull the jumper wires out. I won't be driving the car to the NCRS meet and so it will be cold when they go through the items. Should work. It won't work when it gets hot and the trick is to keep it cool and not run it long.
04-12-2016 | #8 |
I do not know why you are replacing clutch safety except you want to
It sounds like typical starter solenoid to me needs refreshing if in fact it is a no start and especially if the no start happens on a hot engine starter.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-13-2016 at 02:40 AM. |
04-13-2016 | #9 | |
Jet: No start when hot is NOT a safety switch phenomenon. However, that is characteristic of the starter solenoid windings. So, if it is the solenoid is failing, bypassing the clutch safety switch will not be a "work-around" solution to that problem; but a new solenoid will.
04-13-2016 | #10 |
I understand that but the starter is new. In my experience, limited as it may be, it points to the safety switch. However, I will try it out this weekend and see what happens. This has happened before on my 92 Z. I did replace the starter and the solenoid and it still did it. When I bypassed the safety switch, never did it again. Also, I'm looking at NCRS and it has to work at that point. However, by trailering it down, I avoid that. Besides, I have a set of GSC's and I don't want to drive on them 1000 miles.
It only happened one time but it was a time killer waiting for it to cool down.
