Old 03-28-2016   #1
Torchred96
Default Sold! Heads w/valves Left and Right (NO CAMS)
Sold. Reduced to 750.00 plus shipping CONT. US. I'd like to have UPS box these so they have no excuse in the event of damage. My other items I have listed here are reduced too
These are the heads from my 91. The Cam covers are Powder Coated Silver. and SPTV are removed and capped. Engine did not smoke at startup. Will need new cover bolts as I used the SS bolts in my new engine. I sold the cams on this forum already so they are not included. I'm sure there are pics somewhere else, just search my posts here.
Probably best to email me at sirlancair@yahoo dot com
thanks
sam
Torchred96 is offline   Reply With Quote
Old 03-28-2016   #2
Default Re: 1991 Heads w/valves Left and Right (NO CAMS)
Springs and lifters I assume?
Old 03-31-2016   #3
Torchred96
Reduced the price to 750. I'm reclaiming my garage space!
Yes XFIRE, including springs, lifters, valves..only thing missing is the cams and the oil cap. So They could be bolted on as is, Lifters on the driver side are brand new lifters with less than 10 minutes run time. Probably more like 3 minutes as I changed them thinking it would solve the clacking problem that turned out to be the number one rod bearing.
I assume you'd want to clean up the carbon in the combustion areas.
