03-13-2016 | #1 |
Wiring harness part identification
Just bought this restomod harness from lgaff. Trying to identify this box. Has three small gauge wires coming out.
03-14-2016 | #2 |
Re: Wiring harness part identification
I would guess it's the defeat for the resistor pellet in the key. Quite a few conversion harnesses came with a similar box. Could tell for sure by tracing the wires back to the Ecm connector. Wish this harness was available when I started my project!
03-14-2016 | #3 |
In his "for sale" the image seems to show it "connected" so you would follow those wires to the appropriate pin of the ECM and ID those pins. I wouldn't think it that difficult.
The wires needed to be terminated somewhere in the harness, I doubt it was just a supplied "loose part". |
03-14-2016 | #4 | |
03-14-2016 | #5 |
I would see if its for the gauges first
03-14-2016 | #6 |
Looks like B10 ignition feed, D7 VATS, and a ground.
03-15-2016 | #7 |
D7 I'd think more appropriately determined to be FUEL ENABLE - but it seems to interpret the "unknown device's" function or maybe "intended function" and the B10 is actually in OE from the ECM fuse I believe. That doesn't seem to have taken very long and I doubt difficult.
03-16-2016 | #8 | |
03-16-2016 | #9 |
03-16-2016 | #10 |
