Old 03-08-2016   #1
Vette73
Default Air pump....Should I remove it?
Every time I start my engine I have to hear this run, of course it shuts down around 10-20 seconds depends....
I guess you would call it the smog pump..I guess I can find it if I looked but where exactly is it located? Can I just remove it, or is there a kit I have to buy to replace it? I'm sure it's a horsepower robber, of course not a lot but, is it neccessry ?
Had the car dynoed today...Put down 382 RWHP at 7,000 RPM....Torque was anywhere from 347-350 rear wheel at 7,000..
Car does have a hic cup at 3,000 RPM when you lean into the throttle, slight, but you feel it....Mechanic could not feel it on the dyno....Fuel pressure was good and the tune seems fine...
The torque figures were a little erratic...My wires may need changing...They do look a little old but they are not factory ( car has 43,000 miles) Also going to swap out plugs.....Lets hope it clears the slight hic cup..
Vette73 is offline   Reply With Quote
Old 03-08-2016   #2
Default Re: Air pump....Should I remove it?
You can eliminate the Air Pump with NO Codes. The Air Pump only functions on a cold start.
Eliminating the Air Pump TIPS
Old 03-08-2016   #3
efnfast
Air pump or vacuum pump? I don't think I ever heard my air pump run.
Old 03-09-2016   #4
G8nightman
G8nightman's Avatar
It under the drivers side headlight you can unplug and remove.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 03-09-2016   #5
There's quicker way to disable that air pump... But! Take it from me, unplugging it might be your better option
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-09-2016   #6
The air pump does not cost you any HP. I did away with mine years ago, has no effect on smog testing. Like already stated it only runs at startup.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 03-09-2016   #7
Vette73
Damn !!! Sorry about that...I'm sure it will look just fine when it's repaired...
Old 03-09-2016   #8
Vette73
Thank you....Just tired of hearing this thing run at start up..
Old 03-09-2016   #9
nelson007
nelson007's Avatar
I hope this is not a new one. Is this the time when you were drag racing?
Nelson
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 03-09-2016   #10
BigJohn
BigJohn's Avatar
You been off roading again???
