Old 03-05-2016   #1
RussMcB
Default Adjustable ARB End Links
Does anyone know if aftermarket adjustable sway bar end links are available?
I just noticed the bushings in my rear links are NG. I need to replace them, so I thought I'd see if they are available with adjustable lengths (so I can make sure there is no pre-load).
I checked a few Corvette vendors, and Googled for a few minutes and haven't come across any yet.
Thanks.
Old 03-05-2016   #2
JimZRyd
JimZRyd's Avatar
Default Re: Adjustable ARB End Links
I've been looking for these as well, figured I'd do this since I'm installing coilovers and poly bushings and such. I think DRM had some but was very expensive for end links. Haven't found any vendors otherwise. There was a guy on the Corvette Forum that made his own heim joint end links using generic pieces. Thought I might go that route one day but for now just switched the bushings in the stock stuff.
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 03-06-2016   #3
1991ZR1
Try emracingcorp.com. I think they used to be called Exotic Muscle.
1991ZR1 is offline   Reply With Quote
Old 03-06-2016   #4
RussMcB
Nice!
http://emracingcorp.com/scripts/prod...&sortField=sku
Thank you very much!
- Russ
Old 03-06-2016   #5
JimZRyd
JimZRyd's Avatar
That was them. Exotic muscle. My mistake.
Jim Zorgias
Old 03-07-2016   #6
Shrek
Russ, If I can find all my stock parts, I'll have a full set of front and rears available.
I'll go through all my boxes of crap sometime this week.
Jeff
Shrek is offline   Reply With Quote
Old 03-11-2016   #7
lbszr
lbszr's Avatar
Thanks.
The sway bar bracket on one side of where it attaches to the knuckle can be shimmed up to make no preload and longer bolts are needed. Front can be shimmed where it attaches to the frame.
