![]() Join Date: Feb 2010
Where can I find the thread about all the tools you should carry with you. I know I saw it a couple weeks ago but can't locate it now.
Want to be prepared during MR4. Gary
Gary 90-1572 ![]() |
#2 | |
Tools to Carry in the ZR-1 |
Dynomite thanks.
Thats the thread I was thinking of. Where do I get a tow adapter and fuel pump jumper? I have an origional Gordon Killebrew ALDL code analyzer. Although larger it's a must keep and carry.
#4 | |
Lifting and Towing the ZR-1
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-01-2016 at 11:23 AM. |
Some people carry spare parts like alternators? Hahahaha oh my god!
#6 | |
![]() I do recommend TB Coolant Blocked to get back on track ![]() Anyone who really wants to be prepared for some fixing on the road should Block TB Coolant. I can remove a Plenum in less than 10 minutes on the road if I have to and I DO NOT torque the SS Plenum Bolts or put anything on the Plenum Gasket when replacing. There is only relatively light suction and no coolant pressure with TB Coolant blocked. I would say I snug up the SS Bolts with maybe half the torque specified probably around 10 ft-lbs (no torque wrench required). |
#7 | |
![]() Join Date: Nov 2007
![]() Last edited by Paul Workman; 03-01-2016 at 08:10 AM. |
![]() Join Date: Nov 2011
Cliff, somewhere on this forum (as opposed to the other one) you posted up about what you carried and how you packed it. Like Paul said, with MR4 looming... even if he did use that big word that I don't know the meaning of.
#9 | |
![]() That is double or triple the work posting the same information. There is a reason for my madness ![]() And......then the maintenance if the information changes or updated over time on two different web sites. (Registry) Tools to Carry in the ZR-1 I just added the Tire Pressure Gauge to the Registry Tools To Carry in the ZR-1 ![]() Tire Pressure Gauge in the Center Console ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-01-2016 at 10:33 AM. |
#10 |
![]() Join Date: Jun 2015
I just went back over the list, I noted that there is a tire plug kit noted (probably the roadside tool I have used the most in recent years), I did not see anything to inflate the tire. I do carry one of those 12V compressors, but they are bulky. Any other ideas for filling a flat tire once its repaired, fix a flat I do not think is kind to the TPMS, it would take about of those little 10 CO2 canisters me thinks, so that's a no-go.
