Old 02-16-2016   #1
rush91
Default Advice on couple of Z issues....
I decided to go and startup, do some detailing of the Z this past weekend. I hadn't started it in about 3 weeks, as it's been bitter cold here, plus all the snow and salt. So I go turn the ignition on, and see the off button on my climate control flashing.....( Cliff's ALDL Reader is being ordered shortly) But all the buttons flashed when pushed, and with just the ignition on, I could hear a buzzing about every 10 seconds. The car started flawlessly as it always does, and after about 10-15 minutes of warm up, the flashing stopped, all works fine now. Just a weird thing that I've never seen.......
Also my drivers seat wont recline at all. Neither the latch on the back of the seat or the latch on the front of the seat seem to work. I can push either one, and can't even budge the seatback forward at all. All other seat functions work fine, I just can't get the seat to recline forward at all. Any ideas before I start ripping things apart, that don't need to be ripped apart lol??? Would it be the seatback reclining actuator gone bad? Sorry so long winded on this guys.......
rush91 is offline   Reply With Quote
Old 02-16-2016   #2
Jitse
Default Re: Advice on couple of Z issues....
Maybe battery issue....
Let your battery test by a shop.
Low voltage can give such type of problems.
Regards Jitse
Jitse is offline   Reply With Quote
Old 02-17-2016   #3
rush91
Regards Jitse
The car had a new Optima battery put in when bought less than 5 months ago. A voltage meter is now on the must buy list.
Old 02-17-2016   #4
When using the seat controls are you hearing anything like the motor is jammed or are you not hearing anything?
Old 02-17-2016   #5
Jitse
With a battery load tester, you are able to check the battery in a better way, with just a voltmeter you can read the actual voltage but can not read the capacity.
But with an voltmeter and if the battery is drained,you can see if this is the troublemaker.
Old 02-17-2016   #6
rush91
No, all the seat functions work. Side bolsters and lumbar bladders work fine, and the power seat functions work. But if I was to access the storage bins behind the seat, I can't even get the seat back to move at all. Would the seatback actuator be seized? It's like something is jammed preventing the seatback from reclining up at all.
Old 02-17-2016   #7
oricale
I use Red Top Optima's and they very susceptible to cold, ...I have had to replace 3 Optima's in 4 years..
[B][I][COLOR=red]1990 ZR1[/COLOR][COLOR=black] [U]#00077 [COLOR=red]RED[/COLOR]/[COLOR=red]RED[/COLOR] (10Y022 PEP CAR)
[/U][/COLOR][/I][/B][B][I][COLOR=red]1991 ZR1[/COLOR][COLOR=black] [U]#00517 ("Irene")[COLOR=red]WHITE[/COLOR]/[COLOR=red]RED-SOLD:cry:[/COLOR] [B][/B]
[/U][/COLOR][/I][/B][B][I][COLOR=red]1992 ZR1[/COLOR][COLOR=black] [U]#00445("The Revenant")[COLOR=red][COLOR="Black"]BLACK [/COLOR][/COLOR]/[COLOR=red]RED(2016 T.O.D!) [/COLOR] [/U][/COLOR][/I][/B]
[B][I][COLOR=red]2009 [COLOR=red]Z06!![COLOR=black]BLK/BLK rare Linen interior[/COLOR] 707HP!![/COLOR] [/COLOR][/I][/B]
[B][I][COLOR=red]2006[/COLOR] BLK/BLK Z51 (Just SICK FAST!)SOLD)[/I][/B]
[B][I]1996 BLK/BLK LT4 Grnsprt(sold...Twice!)[/I][/B]
[B][I]1991 RED/REDL98(Fell off the shipping truck:([/I][/B]
[B][I]1980 BLK/RED L82(Sold)[/I][/B]
[B][I][B][I]1990[/I][/B] RED/BLK(sold.....In Japan)[/I][/B]
[I][COLOR=black][B][I]2006[/I][/B][/COLOR][/I] [COLOR=red]Mustang GT[/COLOR] ([B][I]mach 1[/I][/B])[B](sold)[/B]
[COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1(sold in Japan)[/I][/B]
[COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1#2(sold)[/I][/B]
[B][I]WAZOO Member...[/I][/B]
[url]www.evolution-motorsport.com[/url]
facebook/evolutionmotorsportengineering
Your Local [url]www.Amsoil.com[/url] dealer/user..
*Victory Loves Preparation*
oricale is offline   Reply With Quote
Old 02-17-2016   #8
secondchance
Are you talking about seat back recline mechanism? If so, these are manual - after pulling the lever you need to push to recline. Or are you talking about tilt function which is motorized?
Old 02-17-2016   #9
rush91
Yes, its the recline. After I push the little switch / lever on the back of the seat, the seat won't recline. I'm holding the lever and pushing easy, won't budge. I try to put some muscle behind it and still nothing. The seat works fine by all the motorized functions. Tilt, forward, backwards......Just the seatback won't recline up.
Old 02-17-2016   #10
rush91
That's not what I wanted to hear lol....but this is why I love this forum!!
