02-04-2016 | #1 |
'89 Pre-production motor for sale at the CF
Saw this on the CF, surely someone here would want to save a pre-production LT5 (paging Brett, Mr. Brett, please pick up any white telephone...).
He thinks it's a '93 but the plenum says otherwise. It seems to be in good shape and other than the air horn it all looks to be there. http://www.corvetteforum.com/forums/...-for-sale.html 'Crabs
02-04-2016 | #2 |
Mint Condition 89 Pre-production LT5
Great Find Crabs
The TB Coolant Pipes are hard lines all the way (Pre-Production) and the Cam Cover Vent Tubes is missing drivers side. Oil Cap and Air Horn are missing. PCV Hard Line on Drivers Side is missing (No Ports on Plenum for that line which is Pre-Production). MAP Bracket looks bent down. But........Mint Condition Pre-Production LT5 Engine I am not sure how it is called a 93' when in fact it is Pre-Production?
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-04-2016 at 12:33 PM. |
02-04-2016 | #3 |
Re: '89 Pre-production motor for sale at the CF
It is possible he just has a preproduction Plenum and the rest of the motor still could be 1993....
02-04-2016 | #4 |
That would explain this "93' LT5" looking like a Pre-Production
02-04-2016 | #5 |
The Mercury Marine # would probably be in the era represented by the seller, according to my mini database. 88 pre-production, active ride suspension or 89 model. It is not a production engine for 90 or later.
