Old 11-27-2015   #1
MuRCieLaGo
Default Vacuum pump not working
Hi,
'91 ZR-1
I just received a vacuum pump from Paul here on the forum. I tested it on a battery to confirm it works. However, when I plug it in the car, it doesn't work. Key on, start, whatever, I just never hear it. I know the pump is working. Is there any fuse I can check?
Thanks!
MuRCieLaGo is offline   Reply With Quote
Old 11-27-2015   #2
Default Re: Vacuum pump not working
If Paul sent this pump,it's a good part. I would look at the wire routing and go from there.
Old 11-27-2015   #3
MuRCieLaGo
Yes it does work, I tested it on a battery. I know the problem isn't the pump. Trying to find in the FSM where is the fuse...
Previous vacuum pump had a lot of water in it so it would make sense that it blew a fuse.
Old 11-27-2015   #4
WVZR-1
Vacuum pump is a 10AMP IN-LINE fuse over near the grounds etc in the vicinity of the battery on the LH rear wheel-house panel? If you have a FSM it's in the image at 8A-201-8 in book 2.
Old 11-27-2015   #5
MuRCieLaGo
There it is, thanks a lot! It was blown so I changed it. Vacuum pump is now working.
However, it turns on every 2 seconds or so when key is on. Vacuum leak?
https://www.youtube.com/watch?v=5FZhPIPWCIQ
Old 11-27-2015   #6
Default Vacuum pump Fuse
Is that the same location of the Vacuum Pump Fuse for the 1990?
Thanks for the information......
Just inside and to the rear of the Drivers Side Front
Wheel House Panel almost directly below the Brake Cylinders
Yes...you have a vacuum leak
Finding A Vacuum Leak
Old 11-27-2015   #7
MuRCieLaGo
Default Re: Vacuum pump Fuse
Quote from Corvette Forum:
Originally Posted by BiZ View Post
Thanks for the suggestions. Problem solved. I got this email today:
"Not sure about a 91 but here's info. on a 90 and 95.
> On a 90 ZR1 the fuse is mounted on the driver side plastic
> fender well right below the end of the brake master cylinder.
> A 10amp fuse is located inside a small black plastic housing.
> The housing is a about 2 inches long and 1 inch wide.
> Going to the housing are two wires. Orange wire from the ignition
> switch which has 12 volts when the ignition switch is in start or run.
> There is a Dark Blue wire coming out of the housing that goes
> to the Vacuum Pump motor.
> On a 95 the Valet fuse which is fuse #17 (10amp) in the main fuse
> block on the side of the dash when you open the passenger side door.
> It provides 12 Volts to the Vacuum Pump when the ignition switch is in run or start. At the pump is a Brown wire. This is the wire that
> comes from the Valet fuse. If the Full Power LED is on, the Valet fuse is good."
Sure enough that fuse was toast.
It seems it is the same location '90-'91.
Let's hope the picture will be useful to somebody!
Old 11-27-2015   #8
WVZR-1
Yes it is and as a matter of fact I believe the 8A-201-8 is the same also.
