![]() Join Date: Nov 2014
hi guys, so installed the nav/bluetooth headnit without trimming the bezel as i got the 6.1inch screen. My only question is does anyone else hroave white noise with the radio on. I was told it i bc you have 2 amp (headunit & amp on each speaker) and it causes distortion. ANyone else expeience this? Any solution to fet rid of the static/whitnoise?????
Can you bypass the stock amps to get rid of distortion Last edited by Johnny5; 11-07-2015 at 06:26 AM. |
![]() Join Date: Aug 2006
Is it same pitch tone or alternator whine?
![]() Join Date: Jan 2004
You need an adapter if you are going to use the stock bose speakers and amps with an aftermarket head unit. I'm using the PAC OEM-1.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
thanks loco bob. Did anyone post a how to for a double din install with pics or very detailed? I've been wanting to get this done for some time now after staring at the kenwood box for months
The only thing i need photos of is what to dremel cut to make sure my double din fits all the way in.
every double din radio is "slightly" different
so take yor time, insert radio and trim a little, as needed. some time you have to cut the back plastic wall behind the radio to achieve the proper depth. and the front factory bezel has to be filed a bit as well. take your time its easy |
Don't try to cut it. It's impossible to cut straight. Use masking tape to mark how much trimming you need and use a grounding wheel and file to grind it down. 90-91 car bezel don't need much trimming.
