Yesterday when I picked my car at the body shop the LT5 was just too much to start in the cold weather. I got a jump and made it to work. The car is on my float charger now, but its time to start looking for a battery. Any suggestions? I would like an AGM battery but so far have had 0 luck finding our size.
#2 | |
![]() Join Date: Aug 2006
http://shop.odysseybattery.com/k/sea...6.102555.0.0.0 |
I see some of the autoparts stores carry AGM battery, but it seems they don't make them in our size. Group 75. Optima does not either. Any other brands or suggestions?
I have heard good things about Odessy batteries in the past. I know a few guys who run their race battery's in their cars without issues. |
![]() Join Date: Jan 2015
Why not just get a good battery from Sears or Walmart? I don't think the LT-5 has any special requirements, does it?
I'd need to hear some pretty great advantages about a battery before I spent $300 for one. |
AGM batteries usually last longer, don't emit any bad gasses, and can handle being completely discharged and recharged without losing any functionality.
A red top Optima will work. Just trim the vertical lip off of the passenger side only of the battery tray. It`ll be a tight fit. I did this a couple years ago.
#7 | |
![]() Join Date: Jan 2004
I love my 1st and 2nd Optima ! I got 8 years out of the first Optima and my second is 4 years old and going strong in spite of dead spells where I left the interior lights on by accident. Going to the Lithium type battery next time because the Optima is 40 lbs which is 4 to 6 pounds heavier than a normal battery. The Lithium battery ( Odessey ?? ) only weight 6 lbs... a 34 lb weight saving. That is a pretty good weight saver if you ask me... I was recently quoted $500 for the lithium battery for our ZR-1s.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black |
#8 | |
I have seen guys use lawn and garden batterys to run their cars. They also would only drive these cars in warmer temps. |
