So clutch is slipping in gears 3 and up.
If I'm going to change it I'd like to do it all; FW, clutch kit, short throw shifter, headers. Looking at 1. 198551 Fidonza FW - 350$ 2. DF930140 Centerforce - 675$ 3. ZFdoc lockout shifter - 250$ 3. Maximizer headers - 500$ 4. Henderson tune -300$ Anyone have an opinion on the parts? Thanks! Jay |
If there hasn't been a significant increase in power from stock, the LT-1 Camaro clutch disk and stock pressure plate work just fine. Hurst short throw shifter is also a less expensive alternative.
Recommned the ZFDOC shifter is worth the extra money
I don't think i've ever just replaced a disk before. Thats okay?
If you're not drag racing it you can go with the l98 or lt1/4
![]() Join Date: Apr 2004
??? I thought the splines on the ZF for a ZR-1 were different from a base Corvette ZF??
![]() Join Date: May 2011
Don't play games with 30-year-old technology. Go right to Jerry and buy the ram dual disk setup. You won't be disappointed.
As for the short throw shifter, it is a preference. A good driver will get through the gears equally as fast. You will be able to sell your flywheel, Slave cylinder, throwout bearing and clutch fork. 400.00 worth of parts. Or you can do like I do and give them away to members that need them. http://www.jerrysgaskets.com/clutch-...nic-89-92-0d1/ |
#9 |
The flywheel bolts are different we need shorter
#10 | |
![]() Join Date: Nov 2011
