Old 08-29-2015   #1
frank12
frank12's Avatar
Default Problem with the air intake fan cabin
turning and always connected,
without the ignition key running and does not stop.
Necessary disconnect the connector for stop working.
The A/C system works perfectly.
No error code.
What can cause non-stop fan ?
That circuit is what controls it ?
AM.C.C.C.
frank12 is offline   Reply With Quote
Old 08-29-2015   #2
WVZR-1
Default Re: Problem with the air intake fan cabin
No error code.
Nearly always is the Blower Control Module that you're unplugging to defeat it presently. Nearly always!!!!!!!!!!!!!
Old 08-29-2015   #3
USAFPILOT
USAFPILOT's Avatar
how about a weak fan
Old 08-30-2015   #4
Replace the blower control module
