Old 07-22-2015   #1
91vettezr1
91vettezr1's Avatar
Default 4 sale: ZR-1 & C4 Parts and collectibles large list
B]I have decided to sell a bunch of parts I have accumulated over the past 14 yrs. I have already replaced everything I can on my 91 ZR-1 and since I barely put 1k miles a year on it, I doubt I will need all these extra parts. I have pics available for all listed. See photobucket link. http://s1246.photobucket.com/user/fr...RTS%204%20SALE
I accept paypal, check and money orders. I will accept reasonable offers on all parts. Shipping extra.
Thanks
TODD CERAMI
21 PARK STREET
BELVIDERE,NJ
07823
908 750 4383
TODDCERAMI@COMCAST.NET (email and paypal address)
COLLECTIBLES:
1. Wall art Thunder at Stillwater Table Centerpiece, # 25 of 25. $550 Very rare.
3)Both variations of the EDS/TOMMY MORRISON posters. Thunder & Lightning (slight wrinkling at bottom right corner $35 & the one with the Helmet & gloves.$45 These are originals not copies.
4) Original GM press photos of the lt5 engine 8.5 " x 11" $25 each. 1st photo pictures lt5 engine in lower caption, lt1 above it. 2nd photo side view 89 zr-1, 3rd photo rear view 89 zr-1. 4th photo 92 zr-1 engine , similiar to Dave Kimble see thru art.
6)1992 GM pro athlete brochure in original mailer .These were mailed to pro athletes back in 1992. $60
7) 1990 ZR-1 owners kit coffee table book, $55 each, 1991 coffee table book $50
8a)1990 Partial ZR-1 Owners kit , Pizza box, 90 driver book,90 coffee table book ,90 video Near Mint . Missing keychain and briefcase. $225
9) 1990 Owners kit video with plastic wallet key $30
10)1994 34" x17" mylar Corvette Admiral Blue dealership poster with chevy frame. $155
12) Tommy Morrison Record breaking Endurance record 8.5” X 11’ card. $25 each
13) ASC original press kit photos of DR-1 (ZR1 convertible) and ASC Spydeer $15 each
14) ASC GENEVE CORVETTE PEWTER AWARD $40
15) Original zr-1 window stickers these came from Old owners kits. 4 different VINS $25 each
16) 1991 NCC POSTER 24" X 36 RARE $70
17) 1990 NCC POSTER 24" X 36 RARE $70
18) 1992 Corvette Delco Bose GM demo CD $35 with mailer
20) 1991 corvette zr-1 prestige brochure $15
21) $20 grand 90 sport zr-1 poster
22) SIGNED CALLAWAY PRINT $45
23) T-SHIRT AND HAT GIVEN TO BOWLING GREEN EMPLOYEES WHEN ZR-1 WAS ROLLED OUT $80 PAIR BOTH NEW/ UNUSED
NOS & USED ZR-1 PARTS, SOME STANDARD C4.
1) NOS LT5 SPARk PLUG WIRES ,MINT IN BOX,sealed."corvette lt5" printed $325.00
2) HP6054 NOS Headlamps , plastic not glass, GE BULB $35 Hard to find.
3)90-95 LT5 Power steering Reservoir NOS 26017982 $100
4)map sensor top aluminum plate, goes on top of map sensor $25
6)92-95 Power Steering pressure hose 77416236 NOS $45
7) Secondary Port Vacuum Reservoir (Part #10067563) holds vacuum $65(1)
8)Hose, Secondary Actuator Vacuum Control Valve #10146221 $115
9) map sensor bracket attaches to rear of plenum #10067781 $50
10)90-95 lt5 valve guide sealed in bag # 10090575 $15 each , I have 25
11) N.O.S GM red replacement wire, no "corvette-lt5 " lettering. Sealed in bags, no box. $60 for the set
12)USED A1097C 90-92 corvette air filter with “AC SPARK” script on side. Correct for 90-92 corvettes. Hard to find and needed for NCRS judging $55
13) A1097C gm air filter in box $30
14) NOS PF970C & these have the correct part # 25014155 black, passed NCRS top flight with this filter. The ones without DURAGUARD are impossible to find. PF970 filter are blue part #25011441. $25 each
15) cam cover bolts #1514330, sealed in bags. Attach cam cover to head. $5 each. I have quite a few of these.
16) cylinder case vent cover gasket sealed in delco bag # 10168682 $15(1)
18 ) Shield, Alternator Blade 1990 - 1995 Model #10153529 $35
21)exhaust manifold round spacers #03983422 $6(4)
22)Hose, Fuel Pressure Regulator 10110987 $25(1)
23)Hose, PCV Valve Connector 1991 - 1995 # 10174350 $60
24)Hose, Cruise Control Servo Vacuum #10110989 $55
25)Grommet, PCV Valve, 90~95 14078872 $25
26)vacuum hose from sec pump to under plenum #10098477 $25
28) original gm wheel weights painted grey different sizes 3 oz, 2oz etc you get 10 weights for $25
29) 1991-1996 Corvette Clutch Hose |braided stainless ,goes from master to slave GM Part # 10150086 $225
30) timing cover gasket 10187758 $25(1)
31) lt5 91-95 Pump, Secondary Port Throttle Vacuum 15198448 nos $165 –
32) Used 90-95 LT5 Radiator part # 3094929 dated 04-90 excellent condition low miles, no leaks $150 –
33) 10193707O / 10282934 rear center hatch trim middle piece came out of 19k zr-1, missing 2 bumpers $60
34) ('91-'96) nos Hydraulic Feed Line GM P/N 12509314 $225
35) Reproduction Cam Cover emblems 1991 or 1990 $35 each
36) 1990 N.O.S. Cam Cover Emblem $55
37) 10110933 top secondary cam timing chain guides nos $40 pair
39) NOS FRONT 13" ROTORS GM (RH)10052204 / (LH)1005220NOS REAR ZR-1 GM ROTORS 10097655,fits either left or right $155 pair
40) used lt5 zr1 LUK FLYWHEEL from 19k zr-1, surface is smooth no issues. 10150026 $350
41) 90-96 corvette upper trim piece driver side, excellent condition no cracks. $65
42) aftermarket complete lt5 hose kit $60
43) 1990-92 LT5 Corvette exhaust manifold shields left complete. right outer shield only $40 all 3
44) used 10156160 antenna , mast doesn't go up $15 removed from 94 zr-1
46) NOS 10225120 Fuel Injector housing gaskets left or right $30 each
47) NOS 1990 Corvette base ,not ZR-1 rear bumper turq. metallic emblem $45 10153697
48) 10153649 Used 91-96 Corvette hood emblem, metal not plastic $20
49) lt5 used connector where both pcv valves connect to pipe $15
50) lt5 nos hose clamps $40 FOR 510153529 lt5 alternator shield nos $40,lt5 10067563 secondary port vacuum reservoir, used but holds air tested $50
51) 90-95 Cam Cover Aneroebic Sealer # 12345980 $20 bottle
52) 92-95 lt5 power steering pressure hose 36-362360 /77416236 $45 nos
54) nos 93-95 egr 12578035 $50 / lt5 rubber piece where pcv connect to.used $20 –
55) 14078872 lt5 pcv elbow $20
57) 1993-95 Corvette LT5 ASR cable used from 55k mile car $75
58) 1990-92 lt5 fr2ls spark plugs $5 each
59) nos Secondary Port Vacuum Actuator (Part #1996743) $135
60) Corvette 84-96 left or right front fender seal 14154943 dated 10/5/94 $30
62) 1993-95 Corvette lt5 platinum spark plugs 5614355 $5 each
63) 1993-95 lt5 nos exhaust manifolds pair $260 25143612 & 25129492 –
64) $45 90's gm cell mint in box
65) nos 96 grand sport Fender stripe 10279781 $50
66) NOS 90-95 LT5 POWER STEERING RESERVOIR 26017982 $95
67) 90-92 LT5 OIL FILLER CAP $50
69) 93-95 ZR-1 LT5 A/C LINES USED. SMALL RUB IN HOSE, DOES NOT LEAK $65 –
70) 10231876 LEFT HAND UPPER FENDER USED $35
71) used left side 14104007 wheel well front $25
[/B]
91vettezr1 is offline   Reply With Quote
Old 07-24-2015   #2
Kwood
Default Re: 4 sale: ZR-1 & C4 Parts and collectibles large list
I'd like the 1990 Pizza Box. Will you take $250?
Kwood is offline   Reply With Quote
Old 07-24-2015   #3
FI250
I am interested in the ash tray door. How much shipped to Wisconsin 54016?
Dave
FI250 is offline   Reply With Quote
Old 07-27-2015   #4
Roadster
Roadster's Avatar
Todd, sent an email from FBodies@AOL.com concerning some parts.
Thanks.......Tom
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-28-2015   #5
Karl
Karl's Avatar
Will take the rear sway bushing kit. Are there 8 pieces in the kit?
Old 07-28-2015   #6
91vettezr1
91vettezr1's Avatar
Prothane 7-1145-BL
google that part for image or go to my photobucket link
thanks
todd
Old 07-28-2015   #7
Karl
Karl's Avatar
Originally Posted by 91vettezr1 View Post
Prothane 7-1145-BL
thanks
todd
I will take it.
Old 07-31-2015   #8
Wayne
Wayne's Avatar
5) NOS 91-95 POWER KEY 12508275 $65
If you still have it I'll take it
Wayne is offline   Reply With Quote
Old 08-01-2015   #9
91vettezr1
91vettezr1's Avatar
key is sold
Old 08-05-2015   #10
Karl
Karl's Avatar
Got the bushings a couple of days ago.
Thanks!
