Old 07-16-2015   #1
Fully Vetted
Fully Vetted's Avatar
Default Found some parts...
While emptying out a storage unit I was going through some boxes and came across a belt tensioner and a water pump. I know the belt tensioner can be hard to find but what about the water pump? They are both used.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-16-2015   #2
Default Re: Found some parts...
How much would you want for the tensioner?
Old 07-16-2015   #3
Fully Vetted
Yeah, I'm hanging onto the tensioner. I'll send it to Mark for a rebuild and put it on the shelf. Just wasn't sure if the water pump is one of those hard to find items.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 07-17-2015   #4
mgbrv8
http://www.zr1.net/forum/showthread.php?t=21756
David Hetrick
Old 07-20-2015   #5
Fully Vetted
I forgot about this article. Thanks, David. Also forgot about the billet pulley that Dynomite came across. Ordered it today as well as 2 tensioners from Amazon ($35 ea).
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
