Old 06-03-2015   #1
G8nightman
G8nightman's Avatar
Default Tech II scanner
Hi everyone
Is this the best scanner for 91 Zr1?
http://www.ebay.com/itm/Tech-II-Scan...157459&vxp=mtr
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 06-03-2015   #2
Default Re: Tech II scanner
The question is "Are you looking for a scantool, or do you want to log the data stream also?" Second question, " does this work on OBD1 cars?"
Old 06-03-2015   #3
G8nightman
G8nightman's Avatar
I want to be able to read the code as well as FX3 codes for OBD1 :-)
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 06-03-2015   #4
A paper clip will do that.
Old 06-03-2015   #5
G8nightman
G8nightman's Avatar
For the FX3 codes as well?
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 06-03-2015   #6
Not sure about that? Coming thru CCM?
Old 06-03-2015   #7
RussMcB
Yes, I did this recently.
Let me know if you need a link to instructions (but I found them fairly easily via Google).
I think the only difference is which pin to ground (C instead of B?).
Old 06-03-2015   #8
G8nightman
G8nightman's Avatar
Can you send me the link. Thank you.
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 06-03-2015   #9
Hib Halverson
Selective Ride cannot send DTC info over the serial data line. You have to use flash code diagnostics for SRC.
The most any scan tester can do is ground the appropriate termainal on the DLC such that the SRC controller will send data, so buying a scanner to work on SRC is a waste of money.
You can duplicate that function by turning the key on not starting the engine. Ground diagnostic link connector (DLC) terminal C of the '89-'93, 12-pin connector, or terminal 3 of the '94/'95, 16-pin connector, then observe the flashing Service Ride light to get the fault codes.
For more diagnostic info on SRC, see this story on the CAC site
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 06-03-2015   #10
Or just get a set of these. Gordon's Fault Code Diagnostic Grounding Plugs
https://www.gordonkillebrew.net/Products
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
