12-08-2006 | #1 |
what the water colant temp. is when the gauge needle is in center position!?
What the water colant temp. is when the gauge needle is in center position ? i always loved the digi gauges on my 1986 vette with F and C reading.... ! any one know it? thanks
12-08-2006 | #2 | |
Re: what the water colant temp. is when the gauge needle is in center position!?
So...get your car warm and when it is in the center position do the above procedure...then you will know. :-)
Uly Past OWNER 90 ZR-1 #0120 Red/Saddle UT Plate: EZR1DER |
12-08-2006 | #3 |
Here is the information that shows the temperature value for several points on the 90 ZR-1 temperature gauges.
Scale %...Oil Temp...Water Temp 0%............100..........100 25%..........191...........184 50%..........220...........210 75%..........246...........232 100%........280...........260 |
12-08-2006 | #4 |
you are talking about arows and up and doen , ?? where all that??
12-08-2006 | #5 |
thankssss alot brother > guinnessdood for mseging me back.
12-08-2006 | #6 |
thanks Tomy too
