Old 05-04-2015   #1
JimZRyd
JimZRyd's Avatar
Default Brake Bleeding Sequence
Hey guys! I'm seeing conflicting info here on the sequence for bleeding the brakes on our Z's. Mines a 94. I've read that somewhere around 91 or 92 the sequence was changed. I've read the traditional RR, LR, RF, LF and RF, RR, LR, LF. I've even read that some do not follow any specific sequence. I am not fortunate to have an FSM handy. Any advice is greatly appreciated! TIA!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 05-04-2015   #2
Default Re: Brake Bleeding Sequence
If I am doing all 4 I do RF, RR, LR, LF but I have done just fronts and rears alone..
Funny thing is I always start on the Right side of the car
Old 05-04-2015   #3
mike100
I have bled mine from RR first. Honestly I don't think it matters too much- front or rear first since the master is two separate reservoirs front to rear so it mainly makes sense to do the longer passenger side run first.
Old 05-04-2015   #4
JimZRyd
JimZRyd's Avatar
Interesting take on the master being split Mike! I agree on it making sense to do the longer passenger side first. If you are bleeding say just the fronts...will only the front reservoir of the master become lower? I would much rather do either the fronts and then the rear, or vice versa, and only have to jack one end at a time. I'm also changing out the rotors and putting on new braided lines.
What year is yours Jeff?
Jim Zorgias
Old 05-04-2015   #5
90..
Old 05-04-2015   #6
JimZRyd
JimZRyd's Avatar
I've read it changed somewhere in the production run.
Jim Zorgias
Old 05-04-2015   #7
I can look in my 96 FSM tonight if time allows
Old 05-04-2015   #8
JimZRyd
JimZRyd's Avatar
Thanks Jeff ! I really appreciate that!
Jim Zorgias
Old 05-04-2015   #9
96 FSM states : RR, LR, RF, LF
Old 05-04-2015   #10
JimZRyd
JimZRyd's Avatar
Thanks Jeff! I still would like to verify that this is the same for a 94 Z. I'm not sure if the brake systems are the same.
Jim Zorgias
