Old 04-30-2015   #1
SteveCanyon
Default LTPMS Question
Quick question about the low tire monitoring system. Does the car automatically detect the sensors? Just curious as I bought a set of wheels and tires with them already installed and want to know if my car will recognize them.
SteveCanyon is offline   Reply With Quote
Old 04-30-2015   #2
WVZR-1
Default Re: LTPMS Question
What year is your car? I believe you just bought A-molds so those sensors would only be "correct" for '93+ cars UNLESS they were purchased from someone who has already "transferred" the earlier '89 - '92 sensors on them.
Part #'s from the sensor labels will identify which.
Old 04-30-2015   #3
SteveCanyon
My car is a 90. I thought I read that the light would not come on in the 1990 cars if there were no sensors in the wheels, is that correct?
Old 05-01-2015   #4
efnfast
I'll be able to answer that question shortly. I just bought new wheels and am going to use an aftermarket TPMS system. Mystic ZR-1 has a 90 also (as is mine) and his factory wheels sit in the garage. No warning light when he drives away from them.
Old 05-01-2015   #5
Is the LTPMS module a stand alone piece? I have no sensors and I am thinking of removing the module all together
(sorry for the semi-hijack, but it is related)
Old 05-01-2015   #6
WVZR-1
If your dash pad is already removed it could be considered quite easy BUT I don't believe I'd go to the aggravation to remove the dash pad to accomplish it. The connector C215 I believe can be seen with the DIC removed. I've never attempted to "fish it out" (for a disconnect) and I don't think you can.
8A-201-2 Fig. 7 in a '90 FSM.
Old 05-01-2015   #7
Thanks WV..
I should have thought of it when I had the Dash pad out last month.. maybe next winter
Old 05-01-2015   #8
I don't have LTPMS sensors on my Z06 wheels. No light. Of course, the bulb may be burned out or have been removed too.
Old 05-01-2015   #9
efnfast
Dom, did you do an after market system, or none at all?
Old 05-01-2015   #10
mike100
My understanding is that each corner broadcasts a different identifier so that the receiver will get 4 different signals. Each wheel corner is identified by a different color sticker and I'm going to say that each p/n is the same no matter what car it is on. There is no need to synch or learn new codes like newer technologies do.
I wonder what happens if you pass another C4 with the same system- would it confuse the receiver? That said, I still get one wheel which sometimes has a weak transmission- the service ltpws comes on. At first it did it all the time, but as the tires wore thin, it got better- now it is acting up again... Next tire change they are getting pitched, but I will say that it has worked to report a low pressure condition when the tire drops below 25 psi. The damn warning light for the ltpws fault is just so bright and I don't want to screw with it anymore- probably pull the light bulb out soon.
