Old 04-23-2015   #1
Default Cornering Bulbs?
What is the correct Bulb number for the cornering light/ side reverse lights on the 1990..
I cannot find the bulb number anywhere
Old 04-23-2015   #2
BigJohn
BigJohn's Avatar
Default Re: Cornering Bulbs?
Did you check the owners manual.
Old 04-23-2015   #3
WVZR-1
I've never seen anything but 1156 mentioned for both the front and the rear. That's what SPO mentions. There should be a specifications section in 8B also. For an '87 in the FSM it's 1156 also. I happened to be checking other things for a fellow.
Old 04-23-2015   #4
I don't have one
Thanks, but for some reason I thought is was different. I will look in the FSM and might just pull a bulb to confirm
Old 04-23-2015   #5
I replaced mine w LEDs
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-23-2015   #6
do you have a part #? that is what I would like to do
Old 04-23-2015   #7
Jeff,
Believe I may have given you a set a year or so ago. They are the tower w 10LEDs. I can check one on my car because I also have them for front cornering lamps. In fact all my exterior lighting, w exception of fogs and headlamps are LED.
Old 04-23-2015   #8
-=JEFF=-
24 is the bulb number for the side markers be careful as the blub retainers tend to be very brittle. 1156 are for the front and rear cornering bulbs D
Old 04-23-2015   #9
Jeff,
Do they fit without modification? I remebered you having to modify the rears?
Old 04-23-2015   #10
yeah he got me a set of rear bulbs like he has (for next to the license plate).. in that design there is interference.. I ground the interference off the bulbs and they fit
I want to replace the white cornering light now.. then I will do the markers and turn signals up front..
then the fogs..
