Old 04-09-2015   #1
efnfast
Default iTPMS
Any experiance with this? Or other aftermarket systems?
Old 04-12-2015   #2
Marc Haibeck
Default Re: iTPMS
I recently installed the Dill 2G TPMS system that Tire Rack offers. I think that it is very nice. It displays tire pressure in PSI and tire temperature. $279.
Details:
http://www.tirerack.com/accessories/...toring+Systems
Marc
Old 04-13-2015   #3
efnfast
Default Re: iTPMS
Thanks Marc. Looks pretty cool. I'm not thrilled with having to install that head unit, shame it didn't work on my phone. Does the unit have batteries, or does it need to be plugged in?
How do we disable the factory TPMS?
Old 04-13-2015   #4
Locobob
Default Re: iTPMS
I looked at some of the phone based set-ups but decided against that as I wanted the tire info in front of me full time rather than on a multifunction device... something to consider.
Robert
Old 04-13-2015   #5
JimZRyd
JimZRyd's Avatar
Default Re: iTPMS
I saw an article a while back for a company called FOBO tire. They had a neat unit that replaces your valve stems and relays the info to a hand held device that could be mounted inside the vehicle. Was pricey though but looked neat. I book marked the site just in case.
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 04-14-2015   #6
Marc Haibeck
Default Re: iTPMS
The display is about 3" x 1.5". I mounted it with a fabricated bracket on the cluster ledge to the right of the steering column.
The display needs to be connected to vehicle power.
The best way to eliminate the LTPMS error lights is to remove the bulbs.
Old 04-14-2015   #7
efnfast
Default Re: iTPMS
Thanks Marc
Old 04-14-2015   #8
WVZR-1
Default Re: iTPMS
I'd think maybe the FOBO system deserves a look BUT it's certain draw-back could be the bulk of the "on stem" transmitter. That aside it eliminates the need for a separate dash display. I've not had a "hands on" but I believe a friend has bought or is considering for his motorcycle. I'll need to ask.
http://www.gizmag.com/fobo-bluetooth...-system/33754/
https://my-fobo.com/
It seems the + version comes with an alarm so that if indeed you left home without your phone the alarm function would still function through that additional component.
Transmitter dimensions are included in this specifications reference:
https://my-fobo.com/Product/FOBOPLUS#specifications
At an inch+ very little it certainly is bulky, remove for shows and displays maybe? It certainly would be conversational. A person if serious and did a substantial amount of driving could add these to the inboard wheel section behind a wheel spoke maybe for a sight unseen install.
