Old 04-03-2015   #1
Roadster
Roadster's Avatar
Default Two Questions that need your thoughts!!!
Just got in from work and no time to check the search button yet.....
Been driving the ZR-1 back and forth to work for the last 3 weeks, due to the 82 being down.....
1- stopped to get gas yesterday on the way home and put down the window for the rest of the ride home. left for work last night and the DS window would not go up....drove to work with the window open and back home today in the rain, not a fun ride.....
The passenger window works fine, but when you engage the driver's window switch, nothing....the volts will drop slightly when moving the switch.
I guess this could be a switch problem, or a motor problem? what is the first thing that I should check for???
2- change oil light came on today and not even 4K since last year when I changed the oil. I did not reset the oil life monitor, which I am assuming it is reading the PO's previous oil change before me.....just looking for clarification, don't want the oil sit there if it needs a change....
thanks for any info, always appreciated.......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-03-2015   #2
Default Re: Two Questions that need your thoughts!!!
Just reset the change oil light, Mine are always off as I change oil on my schedule not thy the light I think it goes off mileage.
Your going to have to remove the door panel to check the window. If the voltage drops its most likely stuck or the motor is bad, sometimes just unplugging and re plugging will work.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-03-2015   #3
gbrtng
gbrtng's Avatar
Change the regulator - you can replace the motor but then you still have the half-worn mechanism. Be ready for lots of cuts and scrapes from all the sharp sheet metal inside the door. Bummer ...
Old 04-03-2015   #4
Demps
Demps's Avatar
Window: until you can fix it right...hold window switch in desired position from inside and slam door closed.
Ted
Old 04-03-2015   #5
Hib Halverson
I've never had a power window problem with my 95, so, if it were me, the first place I'd go for information on how to test the system, i.e.: decide if it's the motor, the regulator, the switch or the wiring, would be the Factory Service Manual. If you don't have one and don't want to get one, then you're going to just have to take a guess as to what to replace first. I'd ignore the stock voltmeter 'cause C4 analog gauges are horribly inaccurate. You could try and measure the voltage that circuit and if you see a big drop when you move the window switch but nothing happens, my wild-assed guess would be the motor.
If the OLM was not reset after the last oil change. Reset it but ignore it. Change your filter now then change the oil at 7500 miles then rest the OLM again. From then on, if you're using factory fill oil or equiv, "obey" the OLM.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 04-03-2015   #6
Hib Halverson
(snip)
The oil life monitor has only two inputs.
1) number of engine revolutions since last reset
2) oil temperature history since last reset.
That data is run though software GM has developed. The light comes on when the oil's additive package is likely near exhausted.
If you use factory fill oil or equivalent, the OLM is very accurate except for two things
1) it should be ignored if the engine is operated off road or inroad in dusty environments
2) the engine is subjected to frequent starts without warm ups.
The question then comes when someone is using a better oil.
I use Red Line 10W30 in my LT5 and change it every two years or at 150% of oil life.
Hib Halverson
Technical Writer
Old 04-04-2015   #7
Funracer
My DS side window does not go up on occasion. Years ago it quite completely.
It turned out to be the switch in the door. Remove the switch and clean the contacts.
Can't remeber too much about it but I might have taken the switch apart to get at
some of the copper.
I did this 7 or 8 years ago and it just now started to do it again. If
you cant get to it right away try pushing the switch forward from the outside
back corner or some other odd angle. Thats what I'm doing now to make it go up.
The biggest concern for me then as now is that I cannot secure the car if the window
will not close.
Try the switch first before you dig deeper. Might be as easy as that.
Regards
Funracer is offline   Reply With Quote
Old 04-04-2015   #8
some of the copper.
will not close.
Regards
Exactly the same thing I experienced with WARP TEN (a '95). Popped the switch out, disassembled it and cleaned the contacts and it has worked fine since. You don't need to remove the door panel for this as I recall. --Bob
Old 04-04-2015   #9
Thanks for the input Hib. I change every 3-5k miles or once a year cheap insurance, so My OLM is always off.
I would think if the switch is drawing power it may be the motor.
Steve
1990 Red/Red #1473
Old 04-04-2015   #10
Hib Halverson
I am confused..........go ahead and tease me as I get confused often
What is 150% of Oil Life.....sounds like you just went past the Oil Life (100%).
No. I reset and the OLM is 100. I drive until it's zero and the light comes on. T?hen I reset it and continue to drive until I see 50%
Uh...ok...I forgot one thing, on a C4 you need a scan tester to actually see the oil life.
In any event that seems to work out to about 15,000-1600 miles which you can do with Gibbs Driven or Red Line 10W40 I change the filter every 4000-5000.
Been doing that since the engine was new and I validate it with oil analysis.
Hib Halverson
Technical Writer
