Old 03-21-2015   #1
jrd1990zr1
jrd1990zr1's Avatar
Default 4 wire electrical connector
Does anyone know the GM part number, availability or a source for the black 4 wire electrical connector to the right side of the throttle body? I believe this is the throttle position sensor.
I learned the lock on the side is very brittle when cold, need a new one.
Thanks in advance.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 03-21-2015   #2
gbrtng
gbrtng's Avatar
Default Re: 4 wire electrical connector
very brittle when old too.
Old 03-21-2015   #3
1991ZR1
Since he said 4 wire on the right side, I think he is talking about the idle air control?
1991ZR1 is offline   Reply With Quote
Old 03-21-2015   #4
jrd1990zr1
jrd1990zr1's Avatar
Yep, my bad, it is the IAC connector.
Looks to be Delco PT757 or GM 12126487 Think I found one.
Old 03-22-2015   #5
WVZR-1
That should be correct for the IAC. It does appear to be NLA from GM/ACD but I'd think it's on shelves at many dealers. There should be replacing part numbers that might be less expensive. You mention "finding one" so you should be all set.
