03-12-2015 | #1 |
Another power antenna question..
Posted a while back my antenna won't go down...I have not really gotten a chance to look at the connections around it..
Allthough the weather in NY has been lousy this winter I still managed to drive the car at least once every ten days ..Did a round trip to Atlantic city two weeks ago... It was real nice yesterday so I had the windows opened when I turned off the radio......I could hear the motor making the noise it should when the antenna goes down...Still antenna is in the up position... Motor? If it is,what year C4 antenna motors would work with it? My car is a 91.... |
03-12-2015 | #2 | |
Re: Another power antenna question..
Rich
03-12-2015 | #3 |
Sounds good....Thnx for the input...
03-12-2015 | #4 |
03-12-2015 | #5 |
I had the same problem with my antenna, changed antenna mast works fine since 2006.
Manfred E............... 91 #906. |
03-14-2015 | #6 |
I've had the antenna apart to replace the mast in mine,fed the mast down into housing with it in the car,by myself, not easy until you get it figured out and have got the wiring figured out for a 93 or later in a 91 of anybody needs some tips.
