![]() Join Date: Nov 2013
I destroyed my antenna bezel on my 1990 Z today while trying to replace my antenna mast. This is my daily driver and would greatly appreciate anybody who has a spare and can part with it😒
Did you try the link that I posted in your other thread?
I did...I looked up the part # in the master catalog and it's A/C Delco 14104620 which is unique to ZR1's. The link has the grommet used by all other C-4s. I may have a bead on one, just waiting to see if it works out. Thanks for the reply!
I did the exact same thing couple months ago, i used a standard C4 grommet and used a dremel to shave it flush. It isn't quite right, but until I can locate the correct part it is ok.
I"m looking at this source as a backup plan...worth checking out.
http://www.hummerpartsonline.com/ind...rtnum=14104620 Are you still in the AF? |
that is the YY part number not the YZ part number. I think it doesn't fit.
