I am looking for a Fuel Pressure Regulator and I am assuming the whole Fuel Rail with the hard lines/connectors/"O" rings between the Regulator and Rails. Ran into a Fuel Pressure Regulator Failure yesterday with Raw Gas sucked into the Plenum. It is Rare but Happens
![]() I have not figured out how to take a Fuel Pressure Regulator apart but apparently the air controlled valve/bellows totally failed with raw gas being forced out through the vacuum port and sucked into the Plenum from the Fuel Rails.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-06-2015 at 11:56 AM. |
![]() Join Date: Dec 2003
Ruptured diaphram. The stock regulator is not made to be servicable. There are alternatives besides replacement with a stock style regulator.
All you need is just the regulator. I have the o-rings, PN 14104675-9V and also a stock replacement regulator. However, YOU would LIKE this! Would be nice n' blingy with braided SS lines & look cool mounted on the RH side of the plenum. http://www.ebay.com/itm/AEM-Performa...item35dd9b26ae ![]() OR..... in your color http://www.dezod.com/pd_aeromotive_a...regulator-.cfm ![]() Come to think of it, I may want to do this myself!
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 03-06-2015 at 01:09 PM. |
You know me too well Jerry
![]() Thanks for the information.......I had no clue you sold the Fuel Pressure Regulator separately ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#4 | |
Considering you are one of my most prolific customers, and the time span, I've had plenty of opportunity to get to know you..... and glad of it!
![]() Join Date: Jan 2015
Seems like it would be a challenge to use an aftermarket pressure regulator with our hard lines. Where and how would you plumb it?
Just curious. |
#6 | |
![]() BTW Jerry any new hats? I need to order a few things.. My DD hat is taking a beating lol and its been washed twice ![]() ![]()
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 03-06-2015 at 02:51 PM. |
#7 | |
1.Single unregulated supply line to regulator, 2. (a) If regulator equipped for 2 regulated outlet lines, then 1 to each rail. If not, then (b) single regulated line to Tee fitting + line from each end of Tee run to each rail. 3. Regulator return to return fuel line Fuel Rails modifications. 1. Weld shut all rail holes for fuel pipe connections between rails 2. Weld AN fittings on firewall end of fuel rails for regulated fuel pressure lines. 3. Mount liquid filled analog gauge direct to regulator I have a set of modified fuel rails somewhere. Will take photo later if interested. The benefit is constant fuel pressure at all manifold pressures, from max vacuum to zero or positive pressure if boosted.
#8 | |
![]() I have in stock, but the same original design. Do you have an idea for a new design?
#9 | |
Maybe the ZR-1 script like our rear end logo, I like the splash logo as well and I can display my my splash pin to it as well like I have on your current hat. ![]()
#10 |
What about the hat style itself, the soft, black denim. Is that still the preferred type? Maybe "Beanies" are the thing at the moment, especially for the NE part of the country.
