Old 03-02-2015   #1
Bolling
Default Throttle tension?
I can tell when accelerating that there are two different tensions when accelerating. The first part of the throttle is very easy and then gets a little stiffer. Is this normal and is it the secondary's kicking in?
Bolling is offline   Reply With Quote
Old 03-02-2015   #2
Default Re: Throttle tension?
The throttle is progressive in that only the small butterfly operates the motor for idle and part throttle mainly, then the secondary throttles plates open (throttle body)
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-02-2015   #3
Bolling
Thanks, that makes sense.
Old 03-02-2015   #4
Billy Mild
Glad I'm not the only one who thought that.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 03-02-2015   #5
Dom is of course correct. But, just to clarify, don't confuse the pressure to open the main TB ports with the Secondary Port Throttles which are located in the Injector Housing and controlled electrically: you will feel no change in foot pressure when opening the SPTs.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-05-2015   #6
Bolling
Thanks
