Old 02-17-2015   #1
SAM/CH ZR-1
Default How much cfm blows the stock fans?
Does anybody know how much the stock cooling fans blow?
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 02-18-2015   #2
WVZR-1
Default Re: How much cfm blows the stock fans?
I've never seen GM rate their fans by CFM, the 90+ C4 fans are designed for I believe 2100 RPM, by a 150W motor and are 11 3/4". CFM can be deceptive. Here's a good read maybe that explains:
http://www.oldairproducts.com/catalog/electricfans.php
A very old "cure chart" from DeWitt on the CF. I'm sure there are more current charts but I didn't look.
http://www.corvetteforum.com/forums/...post1561968603
I had seen this post years ago and was able to find it again. A friend (a painter) pointed it out originally. Similar fans I expect WITH NO LOAD:
http://forums.trailvoy.com/showpost....&postcount=125
