02-10-2015 | #1 |
Small Functional Engine
So Smooth Running that one can balance coins on edge.
See Engine Disassembled and Assembly towards end of Video....... Miniature Operational Engine
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-10-2015 at 10:53 AM. |
02-10-2015 | #2 |
Re: Small Functional Engine
simply amazing !
02-11-2015 | #3 |
Impressive !!!
02-16-2015 | #4 |
Where's the oil system? I see no oil presence on the valve rockers & cams. No ignition system either. Is it running by air pressure? All I can see is a small hose to the engine.
02-16-2015 | #5 | |
"Anyone who appreciates the precision art of engine design ought to get a kick out of this offering from a Spanish engineer named Patelo. Starting with hunks of aluminum, bronze and stainless steel, he spent over 1200 hours designing, milling, turning and drilling what he claims is "probably" the world's smallest V12 engine. Powered by compressed air injection (0.1kg/sq cm), this little marvel boasts a total displacement of 12 cubic centimeters from its twelve 11.3 mm diameter pistons and works like a charm. Best of all, you can see it come together in the detailed video that follows." Actual running small v-8
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-16-2015 at 12:21 PM. |
