02-08-2015 | #1 |
TPS failure
About 2 weeks ago my Z started to miss badly around 2500 to 3200 rpm. Since I Threw in a set of old FR2LS plugs after the the rebuild, I replaced plugs with NGK Laser iridiums. That had no effect. So, I tried another MAP sensor I had - still no fix. So, I was figuring either bad coil/coils or secondary fuel pump. However, I noticed miss was occurring immediately after cold start before being fully warmed up - may be not a fuel pump issue... What was interesting was that the miss would star exactly at same rpm range - between 2500 to 3200 rpm. This led me to suspect flat spot on the TPS sensor. Replaced it and sure enough, she runs fine!
I will confirm this later when I can hook up Jim's Tech 1 but I suspect voltage reading will start at .54 volts and as accelerator pedal is depressed progressively, voltage increase would drop or go to zero and then pick back up. Thought I would share this other Z owners for future reference. |
02-08-2015 | #2 |
Re: TPS failure
So, I guess you won't be keeping that old TPS on the shelf as a spare after all.
Scott
[B]WAZOO Member[/B] [B]'95 Callaway SNAT 450 Aerobody Coupe - Black/Black[/B] [B]'92 Callaway SNAT 400 Convertible - Polo Green/Beige[/B] [B]'91 ZR-1 #1231 - Arctic White/Saddle (SOLD)[/B] [B]'90 ZR-1 #2547 - Turquoise Metallic/Black[/B] [B]'89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black[/B] [B]'85 Corvette 454 Coupe - White/Red[/B] |
02-08-2015 | #3 |
Re: TPS failure
Where can you get TPS sensors at for these old birds?
02-08-2015 | #4 |
Re: TPS failure
02-08-2015 | #5 |
Re: TPS failure
Jim and I am going to hook it up and check what happens to voltage as the gas pedal is depressed progressively with Tech 1 hooked up. This should teach us what to look for with Tech 1 when diagnosing a car with stumbling issue to verify TPS functionality.
02-08-2015 | #6 |
Re: TPS failure
When you replaced the TPS, did u adjust it to .53-.57v w key ON?
02-09-2015 | #7 |
Re: TPS failure
02-09-2015 | #8 |
Re: TPS failure
You will have to show me sometime how you set that. I guess a tech 1 will make it easier.
Rich
02-09-2015 | #9 | |
Re: TPS failure
With key ON, you can loosen two screws holding TPS to throttle and adjust up or down to set voltage in specified range. Then tighten and re-check. Flip the throttle a few times to make sure throttle is seated properly. Scan tool definitely makes this easier to do.
02-12-2015 | #10 |
Re: TPS failure
ahhhh the tps
in the old days with my turbo buick these things would forever go out of adjustment and it was important to get the wot volts above 4.7 or the ecm wouldn't give you the full power we were always grinding out the slots and tinkering with them then some gent came up with "tps enhancer" boxes that would trick the cpu and change the ramp up curve and max voltage to get more mid range torq from the turbos never had one go bad, but I sure thought they were congrats on it being an ez fix
