Old 01-30-2015   #1
Default Anybody got a wiring harness they can cut up?Im
I'm looking for the two plugs and the relay for the antenna for a 91. Not looking for the entire harness,Thanks.
Old 01-30-2015   #2
Default Re: Anybody got a wiring harness they can cut up?Im
you want them off of the main harness?
Watson Headers (2" Primary) - Borla Catback
Old 01-30-2015   #3
I believe these are on the main harness under the rear window trim.
Old 01-30-2015   #4
Okay..
How much wiring pigtail are you looking for?
How much are you looking to spend?
I have a harness, I will not part with the harness, but might consider selling the plugs you need
Old 01-30-2015   #5
Maybe 6 inches. I have no idea what this is worth,throw something out there.
Old 01-30-2015   #6
Let me find it.. I have it stored.. give me a few days
Old 01-31-2015   #7
If you search for Weatherpak connectors, you should be able to find the plugs themselves and transfer wiring over to them. Unless you are saying somebody cut the wiring.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-08-2015   #8
do you have pictures of the connectors you are after? I found my harnesses.. but I want to verify what you are looking for
Old 02-08-2015   #9
The plugs I need aren't Weather pack but are a 3 cavity connector. I've been in touch with Terminal Supply which has all of the OEM connectors and they can't identify the plugs. I'm talking to somebody parting out a 90 so I should find what I'm looking for.
