12-27-2014 | #1 |
Coolant question . GM 1825M ?
Went through An older thread but it seemed to be a mix of opinions on coolant. My 94 has green stuff in it and I was picking up new coolant to fill today and couldn't seem to find any I was convinced would be good. Most of the stuff was universal fill.
Finally I found a green coolant that has quite a few specs listed .. Should this coolant be fine?? |
12-27-2014 | #2 |
Re: Coolant question . GM 1825M ?
12-28-2014 | #3 | |
From what I can gather even though this stuff is approved for the Gm specs and lots of diesel specs it is silicate free and therefor not the stuff I want. Thanks !! |
12-28-2014 | #4 |
12-28-2014 | #5 |
Based on the info in this thread, went to Auto Zone and picked up 2 gallons of their Green Antifreeze with the correct UPC #, this will be for the 94.
Then went over to Advance Auto and picked up 2 gallons of Peak Green Antifreeze which states on the label for: GM 1995 and earlier..... If you already get email from Advance Auto, you should have a $10 coupon which is good to use towards a $25 purchase or more of anything in the store. Check your email, it does expire tomorrow. This will be for the 74 & the 82 when needed. Would like to change the fluid in the 94 before the trip to BG in May....
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 12-28-2014 at 06:45 PM. |
12-28-2014 | #6 |
In Canada we don't have autozone. We have napa and Partssource among others like cdn tire. Seems everywhere I look it's universal coolant. Will try GM tomorrow . I still have the drained coolant I might filter it and just add more water to the mix and put it back in.
12-28-2014 | #7 | |
