12-26-2014 | #1 |
bore sizes of the tensioner housings
we are getting to the end of the timing of the cams .found that trying to put in the right side tensioner was really hard . are the bore sizes of the tensioner body different on the left and right ? are we doing something wrong /.??????
12-26-2014 | #2 |
Re: bore sizes of the tensioner housings
Yes, they are different bore diameters
12-27-2014 | #3 | |
LH and RH Chain Tensioners are completely different including the Housing. Unset LH chain tensioner..........................Unset/set RH chain tensioner (Photo by Craig) LH Chain Tensioner Housing and RH Chain Tensioner Housing with Chain Tensioners installed (Photo provided by Jim Voters) Additional Information regarding Secondary Chain Guide Rattle by Marc Haibeck. Secondary Chain Guide Rattle
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-27-2014 at 02:35 AM. |
