![]() Join Date: Feb 2014
1990 Corvette ZR-1 #2954 for sale @ $28K (CHANGE: entertaining offers over $25K). White on red leather. Only 17,500 original miles. This car is beyond immaculate, and has been lovingly ?restored? (if that is the right term for such a low-mile car. It has also been tastefully ? and very lightly ? modified. Engine work has been performed by Bill Boudreau (ZFDoc), who has clearly stated that my car is as solid as a ZR-1 can be. I am somewhat embarrassed to admit that I have dumped nearly $20K into it over the past year. In no particular order, I?ll just start at the front of the car and work backward?
· New Z51 style airdam · MAT sensor relocated to the front bumper · Radiator recently removed and cleaned · Cooling system flushed and refilled · Headlight buckets removed and professionally resprayed · New open filter lid · Marc Haibeck induction hoops installed · New underhood-lamp switch installed · Marc Haibeck PROM · New silicone hoses · New oil pressure switch · New thermostat, drilled by Boudreau to simulate 160-degree unit · A/C converted to R134?this A/C is ICY! · New stainless FIC fuel injectors · New AC/DELCO ignition coils & spark plugs · New fuel filter · New oil pan gasket · New serpentine belt · Plenum coolant-flow bypass · New oil cooler line assembly · Several new rubber connectors under and around plenum replaced by Boudreau · New billet LT5 plenum plate and numbered MerCruiser MAP sensor cover · New OEM complete clutch assembly installed?feels BRAND NEW · New synthetic motor oil and Bosch filter, new Castrol TWS in trans. · New AC/DELCO battery · New stainless steel headers, ceramic-coated inside and out · New Corsa exhaust system?the rare one with the black anodized tips · ZFDoc short-throw shifter installed by Boudreau himself · New OEM rear leaf spring · New 4.10 Viper gears installed, as well as Haibeck speedo correction gears · OEM wheels powder-coated piano black with machined lips · New black center caps · New Toyo Proxes R888 tires · Newer OEM steering wheel · New shift knob · New OEM console cover · New Kenwood double-din head unit (have all OEM stuff for return to stock) · New Rockford Fosgate speakers in stock locations, looks completely stock · New glass on transparent top (car does have both tops, of course) · New Static-cling shade for transparent top · New top-of-the-line carbon tint · New Weatherboots floor ?mats? · New sill protectors Car was recently treated to a PREMIUM detail costing nearly $1000. Paint was color-sanded, buffed and coated with acrylic sealer. All carpets were shampooed. Driver?s side bolster was re-dyed to look new and all leather was treated with a 3-step cleaning/conditioning process. I also have a custom-made framed display with the window sticker and build sheet that can be hung on your wall or displayed at shows. I know I?m forgetting a bunch. This car is spectacular. The only real flaw that I can think of at the moment is the lumbar bags in the seats. They do not fill. However, the pumps are fine and all other seat functions work properly. The original windshield has very light delamination and a couple of nicks. Let me know if you have questions or need more pics. SERIOUS inquiries only?please do not fill my mailbox with irrelevant tire-kicker questions. Thanks. Last edited by ZBrink; 01-20-2025 at 05:49 PM. Reason: item sold |
![]() Join Date: Mar 2014
Chris, that is one very nice looking ZR-1 to say the least....GLWS
Listed elsewhere, as well. Willing to entertain offers over $25K. Thanks.
Drive it & enjoy(permagrin)
That car is amazing........
All the awesome upgrades and maintenance done. Priced WAY to low!!!!!!! Should go fast, but I hope you keep it ![]() David |
Thanks David!!
BUMP. $25K would STEAL this car!
#9 |
![]() Join Date: Oct 2013
Good luck with the sale,Chris. Someone is going to get an exceptional ZR-1,hopefully in time for Christmas.
#10 | |
I hope you're feeling well. Merry Christmas to you and your family, my friend. |
