Old 11-14-2014   #1
Billy Mild
Default C5 Calipers
How much work is required to adapt C5 front calipers to the C4 ZR1? Can stock ZR1 rotors be used with C5 calipers? What kind of brake lines are required?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 11-14-2014   #2
mike100
Default Re: C5 Calipers
The simple answer is a lot of work. Reason being that nothing fits as it should and unless you get a take off kit complete from another car, you will be nickeled and dimed to death trying to mail order all the stuff. Don't forget to convert to an 18" spare tire from a 2004-2006 pontiac gto. First off, do you have the A-Mold wheels? If not...this will cost a lot.
Old 11-14-2014   #3
mike100
Originally Posted by Billy Mild View Post
... Can stock ZR1 rotors be used with C5 calipers? ...
No.
The only thing the C4 and C5 share is the general hub dimension and lug pattern which allows the swap to be possible.
Old 11-14-2014   #4
Kevin
Kevin's Avatar
I have a write up about this but last time I posted it someone got upset, lets just say the list of parts needed is very long
Old 11-14-2014   #5
Lot a work and bunch of parts.
C5 calipers assuming Z06 Used about $400 ish
C5 Z06 Adaptor Brackets $170
Stainless replacement lines with banjo connectors about $120
C5 Rotors assuming stock $150-200 ranged slotted/drilled more.
New C5 PADS $100ish
The right sized wheels. 17 Sawblades wont fit for instance
a little trimming and grinding as required (Wheel dependent).Im sure im missing a few parts but needless to say Big project, Go boldly
This may be helpful
http://www.zr1.net/forum/showthread....light=calipers
Old 11-14-2014   #6
What Goldcylon said . A-molds clear C5 ZO6 brakes.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 11-14-2014   #8
You need the C5 rotors. C4s are a bit larger in dia but not thickness.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-15-2014   #9
Billy Mild
I was curious since there is a guy local to me selling a set of Base C5 brake calipers for a good price. If it requires that much work, I don't see there being much to gain really.
Looking for a ZR-1
Old 11-15-2014   #10
G8nightman
G8nightman's Avatar
I was think about going with this kit
http://www.vbandp.com/index.php?opti...d=364&Itemid=1
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
