Old 11-14-2014   #1
564crewdog
Default Half Shaft U-Joint Replacement
Hey Everybody,
What's the level of difficulty and time required to swap out the U-Joints of the half shafts. The FSM guidance looks pretty straight forward...is a hydraulic press for a must for the caps?
Thanks!
Rich
564crewdog is offline   Reply With Quote
Old 11-14-2014   #2
Default Re: Half Shaft U-Joint Replacement
Yes the press will help.. however I have swapped them with sockets and a vise, just a but more time consuming than having a press..
Old 11-14-2014   #3
Originally Posted by 564crewdog View Post
Hey Everybody,
Thanks!
Rich
I bought my Spicer U joints from a Drivelne shop and had them also install them and balance the drive shaft* while at it also. That said, I've used a big "C" clamp or a vise with a socket of appropriate size as well as a hammer and a large drift punch (of sorts) on occasion too. FWIW.
*The relatively LOW rpm of the half-shafts may exclude them from need of further balancing.
P.
Old 11-14-2014   #4
mike100
It takes more effort to get the half-shafts out of the car then it does to install the u-joint on a bench imo.
I have done two sets now and I have used sockets and hammers. I would have purchased a dedicated tool, but the aluminum yokes proved to be so easy to work with I have not bothered. It is absolutely imperative that you use the brand name Spicer u-joints or no guarantee that the new ones won't be a tight fit. Those $12 parts store imports will really need to be pounded in compared to genuine Spicer parts. believe me on this.
I also used 25 lb lead bricks I got surplus from a university to set the aluminum shafts on so they wouldn't get dinged up during the process. U can't really do this on a wooden work bench- you might have to get down on the garage floor (hence my soft lead bricks so I can do it on a bench).
Old 11-14-2014   #5
DANA SPICER 5-1350X or DANA SPICER 5-3615X on the half shafts.
Old 11-14-2014   #6
564crewdog
Thank you all! Would you say this job is easy, takes ~5hrs?
Old 11-14-2014   #7
Jagdpanzer
Jagdpanzer's Avatar
A good u-joint source I've used on several occasions:
http://www.dennysdriveshaft.com/c37_u_joints.html
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-14-2014   #8
Same here Phil. And to the OP, I used sockets and vise
Old 11-14-2014   #9
nelson007
nelson007's Avatar
Hello Phil,
I need to replace the half shafts in my 95. Would this be the ones that I need?
Thanks,
Nelson007
http://www.dennysdriveshaft.com/p423...ebuild_ki.html
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 11-14-2014   #10
Jagdpanzer
Jagdpanzer's Avatar
Nelson
That kit will do both half shafts and the drive shaft plus replace all bolts and straps. Its the one I always go with. That way you don't have to look back.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
