Old 11-09-2014   #1
secondchance
Default AC compressor
I am chasing oil being spun up by pulleys. I degreased the front of the motor and sealed water pump bolts since it was oily close to the power steering pump area. This helped but still seeing oil under the AC compressor pulley. Can AC compressor leak oil without loosing refrigerant?
Old 11-09-2014   #2
cvette98pacecar
Default Re: AC compressor
No, However the leak can be small that it will take time to lose enough refrigerant before your AC wont work. My Wife Monte Carlo has a small leak in the Evaporator. It take just under three years to leak enough refrigerant when it no longer will work.
On the same note if you have a 93 through 95 buy a 30# drum of R134A. The Automotive industry is moving over to R1234yf, R134A is going to go through the roof just like R12 did.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 11-09-2014   #3
secondchance
Thanks for the tip.
Old 11-09-2014   #4
Corvettes White
R1234YF. YF means, "Your F--ked"?
Corvettes White is offline   Reply With Quote
Old 11-09-2014   #5
cvette98pacecar
Propane based refrigerant.
I am guessing if your car has 15+ gallons of flammable gasoline, 3 pounds of highly volatile propane is not that big of a deal.
I guess the government is looking at the GWP of 4 compared to 1320 for R134A.
GWP= Global Warming Potential.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
1998 Pace Car
Old 11-09-2014   #6
GSJoe
Great advice, Robert. I bought two 30# drums of R12 in the late eighties/early nineties for my Porsches. I was certainly glad I did not much later. Not only did the price go out of sight, but the law changed so you had to have a license to even buy the stuff. I think I'll start stocking up on R134A right now.
GSJoe is offline   Reply With Quote
