Old 11-03-2014   #1
viperbaron
Default Cooling fans won't turn on
My ZR-1 has been in storage for 2.5 years. All seemed to be OK on it, but it was running hot, so I waited to see if the cooling fans turn on...they do not.
Fans will turn freely by hand, no wires appear to have been chewed through, relays have been reseated and no fuses blown.
Is there an "easy" way to check what might be the malfunction?
viperbaron is offline   Reply With Quote
Old 11-03-2014   #2
Default Re: Cooling fans won't turn on
Do the fans turn on with the AC on? That should should at least turn on the seconday fan.
Old 11-03-2014   #3
gbrtng
gbrtng's Avatar
Add freon to the AC maybe ... if the system is charged, both fans should run when AC is requested. If the system needs to be charged, the
fans won't run and an indicator LED will flash on the control head.
Old 11-03-2014   #4
Pete
Pete's Avatar
I'm thinking you already checked fuses at fuse box.
Check the fuseable links behind the battery one of those is power (+) to the fans i have found link to be good but wire inside insulator was caroded
Get a volt meter check each wire for continuity from the screw post and
about 2 inches past the fused link.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-04-2014   #5
gbrtng
gbrtng's Avatar
If you have no diagnostic tools, here is the quickest way to check the fan circuits.
On the AC hard line along the RH side there are two electrical connectors. Disconnect the rear (smaller) one and turn the ignition on - both fans should run - I don't think the engine has to be running.
Old 11-05-2014   #6
viperbaron
See attached photos.
The fans will spin when jumpered in a test from the battery power connector to the fan lead on the relay connector. Replaced the relays and still no workie.
Yes, the indicator is flashing on initial engine start up. So, I'm off to the parts store to get some Freon to see if that helps.
UPDATE: Freon did not help. AC clutch never comes on. I never get voltage on the lead for the blue & black wire and the Blue & White wire.
