Not available.
Interested in the Engine with Bell Housing, Flywheel, Clutch, Pressure Plate
(including ECM and Distributorless Ignition System Module attached under Plenum and coils). Also interested in Transmission. .......and some other stuff ![]() Including Bose radio/CD, Bezel, Climate Control, and Instrument cluster....... I would pick up (no shipping required).
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-11-2014 at 10:17 AM. |
![]() Join Date: Jul 2004
Those seats might be toast, since parts were left sitting on them. kinda becomes memory foam.
![]() Join Date: May 2011
PM Sent
![]() Join Date: Feb 2011
If I send you an empty box made for shipping corvette targa tops, how much do you want for the removable roof (minus shipping-estimated to be $60-$70).
Sounds like the steering column is missing? If not, I'm interested (presuming it was not damaged). I don't need the steering wheel or shaft, just after the tilt mechanism really.
I would also be interested in the brake master cylinder, brake booster, and brake pedal & mechanism. This is so I can convert my 91 to a 92 brake system. The pedal and mechanism are not ZR-1 specific parts but you happen to be parting a year of C4 that works for me. I would think these items could be boxed/ground shipped reasonably easily and should be easy to remove if the seats are out. Condolences on the loss of the owner. Cheers, - Jeff Last edited by batchman; 11-04-2014 at 04:22 PM. |
FX3 shocks?
What kind of headers are those? They look like long tubes.
Any dimensions at all? I may be interested in them. |
#9 |
no idea I thought those looked stock with the air tubes
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 11-09-2014 at 01:31 PM. |
#10 |
UPDATES TO LISTING REFLECTING INFO ON SEATS AND HEADERS MADE.
