I want to replace the hoses but dont want to run into any complications.Before I jump into this are there any hidden surprises I should expect,any one hose going to give me a hard time?Im going to get a pair of the hose clamp pliers to make the job easier.Thanks.
#2 | |
![]() Join Date: Feb 2009
Rich
![]() ![]() ![]() Join Date: May 2007
Agree the short hose is the biggest PITA. If your upgrading to silicone hoses the stainless worm gear style hose clamps are the WTG as they dont tear up the hoses.
![]() Join Date: Jul 2013
The short thermostat hose is definitely a pain (I know it was out of necessity, but what a design kludge), but also the lower hose to the water pump. For me that one was a mighty struggle, very tough to get back on the pump with any kind of leverage if you still have the radiator and condenser in place. If I had to do it over again I'd pull the radiator and a/c plumbing just to get some additional room.
Mark '90 ZR-1 #1322 Daily Driver, 64k and counting Black/Gray [IMG]http://i208.photobucket.com/albums/bb49/mlitherland/IMG_0326_zps3d50d8cb.jpg[/IMG] |
Is there any tricks to removing the thermostat housing?Ill remove the radiator if it makes the job easier.
#6 | |
![]() Getting the old hoses off is usually the worst ......have a razor blade handy to cut the hose length wise over the coupler. Getting the thermostat gasket to stay into position is most difficult....follow the advice of Scrrem above using a putty knife ![]() I use a bit of permatex gasket sealant just inside the new hoses before slipping them onto the couplers.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-27-2014 at 08:17 PM. |
