Old 11-09-2006   #1
bobbyhi
bobbyhi's Avatar
Default Brake Fluid
One of the winter projects is new brake fluid. Couldn't find anything in the sections for any recommendations on what type (DOT 3 brand name?). I don't do any racing so I need some regular fluid. I know the GM number but was thinking more of Auto Zone, Pep Boys, etc. What say you guys/gals???? Thanks...........
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 11-09-2006   #2
Default Re: Brake Fluid
I see in the 90 FSM to use DOT 3. I've seen alot of guys say Synpower from valvolene is great for street use but I've not tried it and I don't know what DOT # it is.
I'm using carquest DOT 3 right now because I'm chasing some gremlins in my brakes and I'm wasting a bunch of fluid. I think since I have a 90 and the book says DOT 3 I'm just gonna use either GM's or another brand name DOT 3.
Old 11-09-2006   #3
40th#381
Go to a F%$d parts house and get there fluid in the blue can. It has a higher boiling point.
Jan
40th#381 is offline   Reply With Quote
Old 11-13-2006   #4
guinnessdood
guinnessdood's Avatar
Thumbs up Re: Brake Fluid
My recommendation is to use the Motul RBF600 brake fluid...it's about $13-$15 a liter. Next best thing to Castrol SRF ($70 liter) probably. You can find it at Pegasus Racing online.
Uly
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 11-14-2006   #5
I go to Auto Zone, Pep Boys, or Kragen, which ever I happen to be close to, and buy either Castrol, Wagner, or Valvoline Dot 3 brake fluid. I change the brake fluid once a year and they all work fine for street driving. I have been doing this with the same car for 15.5 years now.
Tom is offline   Reply With Quote
Old 11-15-2006   #6
ZR1 MK
I recommend Valvoline Synpower for street use.
Mike
427 cu in LT5
[URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL]
ZR1 MK is offline   Reply With Quote
Old 11-15-2006   #7
evl_twn
evl_twn's Avatar
+1 for the Valvoline synthetic.
evl_twn is offline   Reply With Quote
Old 11-19-2006   #8
95ZR1#418
95ZR1#418's Avatar
Talking Re: Brake Fluid
I thought we where not suppose to use synthetic.
Later-Bob :D
[IMG]http://www.axoplasmic.com/800x600/toponzr1.jpg[/IMG][IMG]http://www.axoplasmic.com/800x600/topoffzr1.jpg[/IMG][URL="http://axoplasmic.com/AXOPLASMIC/ZR1.html"]My '95 ZR-1 Home Page[/URL]
95ZR1#418 is offline   Reply With Quote
Old 11-22-2006   #9
ZR1 MK
Maybe you are confusing synthetic with silicone based fluid. Silicone has problems if ABS is engaged.
Mike
427 cu in LT5
Old 11-22-2006   #10
evl_twn
evl_twn's Avatar
This is the stuff I've been using:
http://www.valvoline.com/pages/produ...asp?product=51
