Old 09-30-2014   #1
Default AC Compressor Connector
I need to find the two wire connector for the AC Compressor, anyone know where I can get one? this is the one on the actual compressor.
Thanks
LGAFF is online now   Reply With Quote
Old 09-30-2014   #2
secondchance
Default Re: AC Compressor Connector
Lee,
I have GM connector catalog in PDF. I look up and identify connector and corresponding GM part number then run search in ebay. Once you have the part number finding one is pretty easy.
Send me your email address and I will email the PDF.
byongyun@gmail.com
Thanks
Old 09-30-2014   #3
secondchance
Found the web version where you can look for connectors:
http://www.acdelcotechconnect.com/pa...tails-catalog/
Old 09-30-2014   #4
Thanks Yun!
Old 10-01-2014   #5
WVZR-1
The information I had ended up being the harness end of the connector I believe and the compressor side should have "male terminal" and a female shell. There were several number changes and it only had '92 applications originally so I just started over.
It should be this:
http://www.mouser.com/ProductDetail/...BjZOg7MQ%3D%3D
In this pdf search 12162343 and the connector body and the mating connector will be side by side and you can confirm by appearance. This is changed part # information from some older documents but I believe these should be correct.
http://delphi.com/connectors/assets/...ure/met150.pdf
The PT561/12125649 is expensive but I believe likely correct, at NAPA that would be an EC1151 - I believe this connector was used most everywhere on many other vehicles. I seldom use pigtails, I don't buy from Mouser often either but their images and info is easier to come by than the people I buy from. I can't see the end view of the PT561 so it's difficult to confirm.
Old 10-01-2014   #6
I will take some pics and look for parts #s tomorrow...thanks
Old 10-01-2014   #7
Terminal Supply has most if not all of the OEM connectors.
Old 10-01-2014   #8
WVZR-1
I believe that Terminal Supply has a location very near "LGAFF" so that could be a good choice. They have the connector in black likely 12162000, I'd use 12045773 terminal and I don't know what color of seal you have, I'd guess blue maybe white but they should have all. Here's their 150 series parts:
http://terminalsupplyco.com/Store/De...228#Categories
They're likely closer to -=Jeff=-.
Old 10-01-2014   #9
That's awesome, about 25 minutes from me....actually I lived around that area for about 5 years, never new they were there!
Thanks
Old 10-01-2014   #10
WVZR-1
Thanks
It won't be your "last" visit, it's good to have a vendor like that close by. My parts are 3 days USPS from me and I always thought that was good. I don't know how extensive their inventory is in every location but I would think these parts should be on the shelf.
