Old 09-13-2014   #1
zrss
Default Help Lowering My Z
I'm lowering my '94 using Vette Brakes & Products kit which, for the front, consists of wedges that I am supposed to glue to the stock spring in place of the factory rubber pads. I have a few questions.
1. The factory rubber pads are about .9" thick, and the VBandP replacements are wedge shaped, varying from .5" to .7" thick. Does that mean the car will only be lowered by .2' to .4'? The instructions with the kit say the car will be lowered about 1" but I don't see how that's possible.
2. The instructions also say that removing the 2 shims on each side, which are 1/8" thick each, will lower the car about 1/2". So same question, why is the car lowered more than the amount of height removed from the spring/shim combination?
3. The spring retainers (aluminum C shaped brackets) which fit tightly around the original rubber pads are too tall with the VBandP replacements and don't "retain" the spring, which is loose and slides back and forth in the retainers. Do I need to shorten the retainers? VBandP's instructions don't mention shortening the retainers. If I don't shorten the retainers, I don't think they will do anything and don't see why I should install them.
Thanks for any help. As you can tell, this is the first time I've done this.
zrss is offline   Reply With Quote
Old 09-13-2014   #2
USAZR1
USAZR1's Avatar
Default Re: Help Lowering My Z
Here's a couple of links to help you out. I'm going to lower our 94 at a friend's shop next week and will be installing a VB&P adjustable front spring. In the rear,we're going to install a pair of 11" long 14mm bolts to replace the oem 9".
I'm looking to drop the car 1.5"-2" at both ends.
http://zr1.net/forum/showthread.php?...light=Lowering
http://forums.corvetteforum.com/c4-g...-my-96-c4.html
Old 09-13-2014   #3
zrss
Thanks. I'm hoping to finish mine up next weekend. I'll install the aluminum shims and see how if I like the height and then make changes as needed.
Old 09-14-2014   #4
mike100
To answer why the math doesn't add up on the wedge and shim thickness- it is because it isn't just a spacer--the preload or initial tension of the transverse leaf is greater with the stock bushings and shims pushing the center of the spring closer to the ground. There is no lowering of the car per se, as the spring pad on the a-arm and ball joint never move and you always will have the same travel as stock, but all you do is unspring the spring a bit to reduce the spring effort against the a-arms and therefore it drops about an inch.
You might be lowering the CG of the car a bit, but for the most part you are actually reducing the performance of the spring as you now have to compress the car down on it even further to get back to the tension you had stock. The VB&P straight/adjustable spring might be a better choice. Additionally, hacking the bushings off of your hard-to-find ZR-1 stocker is kind of a one way irreversible mod.
As a compromise, I would only remove the shims which will drop it only .5 inches. Don't forget to have the brackets machined shorter if you cut the bushings
Old 09-25-2014   #5
USAZR1
USAZR1's Avatar
How did the lowering on your 94 work out,zrss? Here's a pic of our 94 before I filled the fuel tank & raised the rear ride height another 1/2" to bring the rake angle back to where it needed to be. Will take another pic soon.
(I need to learn how to take better photos)
Old 09-25-2014   #6
5ABI VT
Zrss you don't need to cut the retainer. Rebember the spring can be moved higher up in it's location so just put the stock wedges under the spring to take up the slack and then the retainer will hold the spring. Hope that makes sense , just remember that you are raising the spring in it's mounting location so adding underneath the spring only fills space.
Old 09-25-2014   #7
PhillipsLT5
PhillipsLT5's Avatar
Call VBP, always helped me over phone
Old 09-25-2014   #8
Racinfan83
Where are those "two shims" at on the front? Can those be easily removed and if removed do you have to do anything to compensate?
I wouldn't mind dropping the front of mine 1/2" if it is a fairly simple process...
Old 09-25-2014   #9
USAZR1
USAZR1's Avatar
Old 09-26-2014   #10
zrss
Lowering didn't work out quite as I hoped. The nose is a little less than 1/2" inch lower. I removed the factory rubber pads, installed the VBandP pads, and reinstalled the shims (my car has a green spring), which the instructions said would lower it about a full inch. If I get ambitious I may remove the shims to get more drop and see if that gets me close to the 1" drop I was looking for.
I like the look of USAZR1's car but wonder if that's not a little too low, at least for the washboards they call streets where I live.
