Old 09-10-2014   #1
Billy Mild
Default Suspension Settings
It seems on this car that the suspension doesn't seem very tight. The car does seem to flex a lot, and I noticed it is really bad when the roof is out. Is this typical of the C4? My 86 951 was pretty stiff chassis and with a refreshed suspension handled decent, but still had some body roll.
On the ZR1 when I have the car in touring mode it just seems to bounce around a lot and be floating on air. With the suspension firmed up a bit that feeling goes away, but the chassis still seems to flex a bit. I think 90% of the rattles and creaks are from the chassis flexing so much. Are there any fixes for that, or is this caused by bad suspension bushings? How often do the shocks need to be rebuilt?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 09-10-2014   #2
Harvie
Default Re: Suspension Settings
Weld a roll bar in right behind the seats. Bar stiffens up the frame.
Charter Member (since the 91) of the 1ST ZR1 Registry
1st vet $157.59. mo for 3 years new
2nd new 1 check & STILL eating funds years later
[-X show poodles & trailer queens :-({|=
Fast and fun not pretty in pink.
Harvie is offline   Reply With Quote
Old 09-10-2014   #3
Kevin
Kevin's Avatar
Have this same issue, of course PA roads are rubbish
Old 09-10-2014   #4
Z06scentair
Z06scentair's Avatar
Typical C4 complaints and is the main reason I never romove the roof panel on them.
The C5 FRC/z06 is my favorite ride/handling car of all corvette's. The fixed roof makes them feel so tight yet quick on their toes.
Z06scentair is offline   Reply With Quote
Old 09-10-2014   #5
mike100
the roof panel is critical. I had a cracking clear plastic top and once replaced, it felt like a whole new car. Along those lines, the FX3 adjustable shocks feel a lot better after a rebuild, especially if you valve them with more rebound damping. I never drive in the soft modes- it will crash to the bumpstops over speed bumps just about when going real slow. Another option might be to get a reprogrammed fx3 shock controller than adjusts them stiffer at lower speeds. My shocks had 27k miles on them and absolutely sucked, but felt great after rebuilding. Bilstein doesn't really want to support these shocks anymore though as their prices are through the roof.
I have also installed the DRM rear trailing arm bracket which affects the anti-squat and seems to have reduced the nose down pitching under braking too. Raising the front end to stock ride height also helped preload the front spring to a stiffer initial tension and gives the shocks a bit more time to damp movement before bottoming out. All these small changes really makes it a pleasure to drive hard and it doesn't feel like a bloated tuna boat anymore.
Old 09-10-2014   #6
Sounds completely normal, I leave mine on sport or performance..tour is to soft . Never take the top off.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 09-10-2014   #7
Kevin
Kevin's Avatar
Unless you have one of the Targa Truses. Would love to get one of them
Old 09-10-2014   #8
batchman
I come from the land of topless Mustangs so with the roof on the car doesn't seem too bad to me .
The spring/shock/bar package from the factory is all "touring" however. Doubling the spring rates (with shocks to match) is a start, and doesn't kill the ride. I was really really surprised that an option package as spendy as this did not get the very good Z51 stuff.
Cheers,
- Jeff
[/I]
Old 09-10-2014   #9
Meanmyz
Meanmyz's Avatar
I haven't read everybody's post in this thread, but it sounds like you need to check out the thread's on the new frame stiffening product. It was designed by Gordon Killebrew.
Here's a thread on the subject: http://www.zr1.net/forum/showthread....rame+stiffener
That and some revalved shocks might make you really happy!
Meanmyz is offline   Reply With Quote
Old 09-10-2014   #10
Kevin
Kevin's Avatar
just bought that set up, haven't put it on, but I drove David's car with it and had to buy one. Makes a huge difference
