09-07-2014 | #1 |
Throttle lever cover screw
Looking for a black oxide finish M4.2 x 1.4 x 8 screw used to attach throttle lever cover to the front of the air horn.
09-07-2014 | #2 |
Re: Throttle lever cover screw
09-08-2014 | #3 |
09-08-2014 | #4 |
Just run the tip of the screw across an emery board file or use a dremel or whatever you have available. The dimensions of Jerry's matches the GM spec so how long is yours that you received? When you arrive at the desired length secure it with Devcon, the screw will remain removable if you use Devcon.
09-08-2014 | #5 |
I will try your suggestion.
Thanks! |
