10-30-2006 | #1 |
normal idle rpm 93 ?
I have and idle of 1100 is that correct?...seems a bit of a fast idle.
jason |
10-30-2006 | #2 |
Re: normal idle rpm 93 ?
If your car doesn't have a chip in it its 650. Mark raises it to 800 if you have a light flywheel. Can you lower it by blipping the throttle ?
10-30-2006 | #3 |
no it stayed there all day long....seemed odd to me. I thought this was computer controlled anyway, so I doubt I can have it set lower can I?
10-30-2006 | #4 |
See if a vacuum hose came off the back of the plenum.
Common after backfire and will result in high idle. Ted |
10-30-2006 | #5 |
will check that, no backfire that i have heard, thanks
10-30-2006 | #6 |
Acouple of things to ck. The idle air control valve .take it off and see if that passage is dirty. Do you have a service manual ? if you do i believeit gives youhow to ck the throttle cable. also see if the tps voltage is .54 hope that helps.
10-30-2006 | #7 |
I don't have the service manual yet, but I will print this out and take it to my mechanic and have it checked. I'm not a wrencher by any stretch of the imagination LOL
